LITHONIA LIGHTING - 11241DP RE - DIAMOND PLATE - TWO LIGHT LINEAR FLUSH MOUNT CHROME FINISH WITH WHITE ACRYLIC GLASS
Collection: Diamond Plate, Width/Diameter: 49.88", Height: 2.88", Length: 7.63", Lamp: 2-32w bulb(s), UL: Suitable for damp locations, - Desc: The diamond plate housing gives this fixture its unique look. It matches many diamond plate cabinets and work benches. The lift-and-shift white acrylic diffuser allows for tool-free lamp replacement. Utilizes (2) linear T8 fluorescent lamps for energy efficiency, superior color rendering and long life (not included).Standard with 120 volt, 60Hz electronic ballast ensures no flickering and quiet operation without interfering with other electronics. For use with non-dimmable switches only. All mounting hardware included. LISTING CUL listed to US and Canadian safety standards and suitable for damp locations and ENERGY STAR® qualified. WARRANTY Guaranteed for two years against mechanical defects in manufacture. Shade Included. / Warranty: Two Year.
Price: 81.00
© 2018.
